rob88
Ingen VW Ort: Göteborg |
J.Wibring
Golf 3 "Eis blau" Ort: Jönköping |
| Lör 29 mar 2008 1:45 |
Hoppas översättning till engelska duger.
* suitably for gulf II
* Engine all 1,8 GTI+16V
* 226x10mm (not ventilated)
* unit price
* without TUEV!
Type of sport brake disk S type s-special-brake disks from high-charred chromium-nickel stainless steel casting. Each disk is reciprocally provided with grooves and conical holes. Thus a lubricating film from water, oil, bitumen particles, rubber abrasion, exhaust arrears etc., always existing on the disk, is interrupted. This leads to a clearly shorter response time. In addition the holes and in particular the grooves prevent the glazing of the brake linings, which constantly?gereinigt? become. This effect leads likewise to an improvement of the braking action. By a better heat emission by the holes overheating problems and the danger become in particular?Fadings? decreased. The depth of the grooves serves also as wear indicator. The used material corresponds at least to the original equipment manufacturer quality.
Tack till http://babelfish.altavista.com
MVH jonas
